altruistica
Member
Just been reading about balanced and unbaalnced inputs & ouputs and now I'm confused!
Hi Guys,
So here's the deal.
I picked up a rackful of old GPO (BBC) patchbays (1/4" stereo jack type) that are balanced along with loads of connectors (I paid less for the whole rack than to buy even a quarter of the connectors new).
Now I want to incorporate all my machines and mixer into this scheme.
My mixer is a Soundtracs PC Series with balanced inputs, unbalanced inserts, tape returns and group sends (it's an inline console with group outs on every channel) are balanced. These are all on stereo 1/4" jacks.
I want to connect two Tascam MSR16 (unbalanced phonos), and two MS16 (unbalanced phonos or balanced XLRs). I've mocked up a couple of inputs and outputs to see if it works and I can't get past the difference in level between balanced 'group outputs' (+4) going to unbalanced MSR inputs (-10). I have wired the 'hot' tip output on the group output (at the patchbay) to the signal (tip) of the unbalanced lead (at the patchbay) which leads to the phono connector to the MSR input. The signal reads -10 on the mixer group output, but '0' at the MSR. The MS16 is wired to the same point on the patchbay and shows -10 when wired to the XLR.
I wanted to be able to know that when the mixer read '0', that the MSR and MS16 both read '0' but I think I'm probably misunderstanding how balanced and unbalanced equipment playa together (or not).
I am also wanting to incorporate either a Tascam MX2424 or Behringer X32 RACK (both on balanced XLR ins and outs) also into the equation at some point. I'm ultimately wanting to track on tape, then dump to PC /MX2424 whilst perfecting the mix to save wear on the tape machines, then play the final mix back off tape.
Any help much appreciated.
Al
Hi Guys,
So here's the deal.
Al
