Ok, since we're in tutorial mode here (you don't mind, do you
?), can you tell me about the stacking of multiple limiters a bit more?
I don't use a PC/DAW set-up as you and most others do, so I don't really know the FX capabilities you have, but do you stack the limiters all in sequence and master at one pass, or is it a matter of running the stereo bus through one limiter at a time, adjusting to taste and making additional passes? I'm guessing the former, as the latter sounds really time consuming.
I ask as I'm not too happy with my faux mastering results. I come in at a reasonable level (typically -14db to -10db peaks) and then I run it through a comp and a limiter all at once getting it as close to 0db as possible without clipping. The tonal balance can shift quite noticeably at this last phase. Sometimes for the better, sometimes for the worse, but always at least somewhat different. I would like to be able to raise the overall level of the master without altering the tone of the final mix so much (unless I consciously choose to do so). I guess that's what everyone wants? Anyway, I'm just wondering if you're on to something there.
I would like to learn how to "tickle" my mixes, rather than beat them to death.
