B
BeagleFaceHenry
Member
I apologize if this a mixing 101, but is it possible to override automation?
I find that after I get everything automated the way I want and listen to the mix through the limiter, I generally want to make subtle changes to a track volume. However, I can't slide my fader up once I've created some automation, correct?
Does my question come across? Once automation is in place, the fader no longer controls the volume, is that correct? What do I do if I want to nudge the volume of the entire track (automation included) up just a bit? Do I have to edit the automation nodes? I don't want to believe that's true because it's so cumbersome when trying to dial in a mix.
Thanks!
Thanks!
