L
lancelot0888
Hi! Please criticize my vocals and mixing here.
The instrumental are not mine. Thank you!
OK, your vocals are getting better, but you seemed hell bent on the grunt. Have you experimented with your voice? Try relaxing it a bit and see what it brings. The recordings I can remember it seems like you are pushing for a vocal sound that might not be you. Try changing it up a bit see what results you get.
I hear some sound distortion in the vocals, not sure if it is source clipping. If it is, turn your inputs down and add the gain during the mix. That would bring your level up.
I understand this is supposed to be free flow, but it seems too free flow. I doesn't complement the guitar or the guitar doesn't complement. Just sounds disjointed.
Overall, you are getting better, you should try and post your next recordings with a different approach to the vocals. Hey, see what happens. And by the way, just ask for feedback, criticize is so negative.![]()
The distortion is distracting, you should have no problem getting rid of that. I'd try playing with a drum track (even if you erase it) so you get used to be held to some closer timing. Nice rhythm guitar. Vocals aren't bad, a lot of potential there.
