J
Johnny Don't!
Great info here from everyone, but I noticed that none of the responses mentioned microphones. If you to achieve this particular sound, you should probably use a high-end dynamic mic (think Shure B7 or an EV RE20) to track both the lead and the mult; that's what a lot of producers and engineers were doing back then. All of the vox on the album "Thriller" were recorded using a Shure B7.
That being said, I agree with a lot of the other input: definitely de-ess the mult track quite a bit OR try not to sing the sibilants when tracking it. And depending on what sound you're going for, I would process the mult track a bit differently in terms of compression and effects. Where you place in the mix relative to the lead track depends on how thick you want the mult to sound. Also, there *might* be use for a phaser or flanger on one of the vocal tracks to give it that thick sound.
Just my two cents. Good luck.
