bouldersoundguy
The 3:1 rule of thumb is a guide for isolating multiple sources and multiple microphones by exploiting the inverse square relationship between distance and signal strength. The goal is to get each mic to pick up its intended sound source without picking up other nearby sources. This helps minimize phase problems (two mics, one source) and bleed problems (two sources, one mic).
Note that the 3:1 rule of thumb assumes similar sound levels from both sources. If the levels are substantially different you may need to increase the ratio to achieve sufficient separation.
Distance B should always be at least three times distance A:
The 3:1 rule of thumb doesn't apply to this situation:
...I mean, it could just be a publicity shot.
