heatmiser
mr. green christmas
True...I'm going to go fiddle with the 2 PUs now and see what I can do. Thanks!
The pickups are not exactly just perfect generators. They are also highly resistive, heavily inductive, and slightly capacitive and they are connected to several loads both resistive and capacitive before we ever hear them. Basically that means that the pickups, controls, cable and [amp or pedal or whatever] input act to create one big complex low pass filter.2) What is the relationship between the two PUs?
Yep, it's up to you. It almost makes sense to me that the bridge pickup be louder, since it's maybe a bit more likely to be used for leads.That's where I think I may have to decide to either have 3 separate tones I love, with one being a little too loud, or compromising a little on tone and having the output of each setting more similar.
By that I'm talking about wiring the neck and bridge pups in series with one another like I described in that post. It's common in old cheap guitars, and is also the 4th position on the Tele Baja switch. It's a pretty easy mod to add, and really rocks in certain situations. It's exactly like having a humbucker with the coils spaced very far apart.May I ask exactly what this refers to? The N*B series connection is really pretty mean and crunchy, and I strongly suggest trying it if you get the chance.
(Sorry!)
