The best way that I can explain what I want to do is this. I want to create a piece of music that does not sound like a canned progression. I fully understand music theory. At this point in my life, BIAB is great for basic sketches of a piece, and tells me where I want to go with it. However, it doesn't let me create the piece. I can hear what I want in the song, but I can't make BIAB do it. I have to create it. That's the best I can explain it. I understand how the different programs work, basically, however, my problem right now is that, if I create a piece for instance in the key of C, and want to go to an F, I have the perfect loop but it is in Eb. What do I do now?
I admit that I don't understand all of the functions that the programs will perform, but one has to learn sometime, and I am willing to put in the time to do so, I just need a little help. The programs that I have are Sonar X2, Acid Pro 7.0 Cubase 5, FL Studio 10 and BIAB 2013, and as I said previously, any help I can get will be greatly appreciated.
Raymie
Ah, gotcha.
Okay, a couple of general points, and then one specific one.
I agree with Manslick -- it's easier when someone can explain as you go, and the music store idea is a real good one. If you're lucky and they're not busy, someone might even show you on the spot
Sonar transposes by going to the properties for the MIDI or Softsynth track and just specifying how many semitones you want to raise or lower the track. You can also transpose an individual clip by using Tools.
Audio tracks are more involved and, as far as I know, can't be transposed using only Sonar. I use a program called Melodyne by Celemony.
Melodyne, which can work as a standalone, or as a plug-in for most DAWs, will raise and lower pitch by semitones, or in finer increments, without changing the tempo. However, it's not a perfect solution. Though it can handle polyphonic music, the best results will be achieved with a monophonic track.
I'm still not clear what you are trying to do. It sounds like you are trying to import BIAB loops into a DAW and then work with them there. That's not a good methodology. Rather than importing the loops, I'd suggest roughing out the entire song in BIAB, then importing the entire MIDI output into your DAW. Then you can modify individual notes, add music, or use the BIAB tracks as a guide to laying down new music.
The real problem is that BIAB and DAWs like Sonar and Cubase have very different intended purposes. Though most DAWs support loops, they're primarily used as shortcuts so that you don't have to lay out a long track that consists of a consistently repeating pattern; DAWs are designed for composing. BIAB, on the other hand, is a shortcut for creating music; it makes accompaniment choices so that you don't have to.
There's an excellent book on Sonar called Sonar X2 Power! by Sccor R. Garrigus. It will take you, step-by-step, through all of the functions of Sonar. I refer to it when I need to reference obscure functions that I don't normally use. Sonar (and Cubase) are dense programs with a lot of features. You don't have to understand all the functions of the programs in order to work with them effectively, but it sounds like you really need a solid introduction to DAWs, generally, and Sonar (or Cubase) specifically.
Sorry I can't be more helpful.
