T
Tomcat Music
Hey Everyone,
I recently purchased a Behringer 2442 and a Delta 1010; I have a few questions regarding balanced / unbalanced connections.
1. Should "Aux" inputs/outputs all be balanced (+4) if possible? It doesn't specify in the Behringer manual if the outputs are balanced/unbalanced however my rack units have the both options.
2. On the topic of "Aux" connections; do they run out of the "Aux Send" then back through the "Aux Return" into the same channel?
Or does the "Aux Return" go to the separate Aux/FX section with only the original signal continuing through the channel?
3. I have 8 unbalanced outputs from the Behringer 2442 going to the 8 inputs of the Delta 1010 (set to unbalance to match the desk).
Although these are unbalanced, when I return from the Delta 1010 to the Behringer 2442 should the lines be set to balanced?
4. For any Delta 1010 experts out there, I have some distortion in my left speaker occasionally, I have checked all mixer lines/inputs/outputs and it doesn't matter which return I am using (1/2, 3/4, 5/6, 7/8) the left speaker is always the issue, I am certain it is either a software or line issue.
Has anyone had this occur before, and does anyone have a solution to the issue?
Thanks for your time,
Tomcat
Tomcat
