R
romi1212
Member
hope u like this cover
Great stuff Romi.
Careful on the timing at the end of the bridge where you say ".....have you near me"...it's a little late and it threw the timing off for the beginning of the next part. Also, unless you're playing with another guitar player, I wouldn't bother doing the solo. It sort of falls apart all by itself.
Are you sure all the chords are right? Something weird with the very ending to me.
Your voice is great, and when you're on you're on.
OK, that's cool. I wasn't saying it was wrong, i just thought a few chords near the end weren't perfect. For example, I thought the very last chord of the song was missing a note to make some kind of 9th chord, but I could be mixing it up with another Beatles song.thanks a lot rami there is a key shift right from the start of the solo
the last part of the song i played was from G minor including the solo as per the original which is half note up from the original scale
may be thts why it sounds a bit different
and the whole song has the scale of F#minor
I realize the solo modulates a semi-tone, you did the change right. When I said it falls apart by itself, it was just because a lead solo without a rythm backing it up sounds a little empty.
Anyway, these are all nit-picking specifics. In general, I love all your versions of the songs you do.![]()
Agree with Rami, the bass part as well seems to throw of your timing, if you can figure out how to roll off of that faster would sound better. The part is so key to the song, it is hard not to put it in. This is just a question and not intended to be negative, could you do an octave lower to give your voice some room? Seems like your voice was having to work hard to sustain that high range.
Good stuff. Keep it up.
Some Beatles tunes you hit on the head. Maybe you feel/know them better or maybe they strike a chord with me, I dunno. I liked your last one better than this one, but this song is more difficult, so it seems unfair to say that. I just wanted to say your playing is great, and really varied as well, you're not put off by trying new things which is commendable. I should definitely take a leaf out of your book.![]()
Can't listen/watch at work, but the last chord is a C major if you do it in the Beatles key. (change from previous pattern of Fm - Cm)
