J
jaynm26
I seen some mostly go after I have also seen some after corrective EQ (Ken Lewis, Tal) So what do you guys think the best place for it and why?
I *almost* always use the de-esser first in the chain if possible. It's basically being used as a fast-acting EQ. A compressor will "see" and use that excessive energy.
These days I never even bother with a de-esser...I have a hardware unit that's been sitting in my racks unused for a long time, and AFA software plug-ins, I don't bother with them either, because once the vocal is in the DAW....I just go through the track and slice-n-dice wherever there is sibalance...then I manually adjust it either by lowering the volume of the "SSSS" portion or by applying some narrow bandwidth EQ cut in the appropriate frequency range...and sometimes I'll use both, because if you cut narrow frequencies to much, you can get weird sounding vocals, so a little narrow EQ cut and a little overall volume cut of the "SSS" and I can usually make most any sibilance sound perfect.
The other trick that is even easier at times is to simply go find a word with similar "SSS" sound...and just cut out the problems and splice in the good version.
I'll pull 2-3 really nice "SSS" sounds out of the vocal track...and just use them as many times as needed.
You couldn't tell the difference with a microscope or hearing aid....and in the end it sounds great.
With the editing power of a DAW....I've gotten more and more away from applying global processing on a track in order to fix specific issues. It's much more surgical to slice-n-dice and just zoom in on the trouble spots.
It takes a bit more time than just strapping a comp/EQ across the whole track...but IMO, much better results.
The compressor doesn't really see the S's, it just turns down everything but the S's. So it makes them seem louder and worse. Knocking the S's back before compression will help. if you put it after the compression, it sometimes makes it harder to fix because the compression will make the S's longer and more pronounced.
Fairview Mo says Comp>Desser helps the desser to react more consistently as the esses "WILL" be attenuated by the comp. We got 2 diff views here WHO IS RIGHT!!???Actually I find that before the de-esser helps the de-esser react more consinstently as the esses will be accentuated by the compressor.
Cheers![]()
...Im confused some more posters please weigh in please.De-essing should be done before the sound hits the mic.
Yeah, but that's not always realistic or easy.
You can put up a pop filter, tape a pencil to the microphone, have the singer stand off-axis, and any other trick...and sometimes the "SSSSS" sounds just end up being too pesky when you drop the vocals into the mix even though they are not very bad when recording.
I've posted twice in this thread with arguments for both ways. It is completely situational. It depends solely on the signal, the other processing and how it sits in the mix.Fairview Mo says Comp>Desser helps the desser to react more consistently as the esses "WILL" be attenuated by the comp. We got 2 diff views here WHO IS RIGHT!!???...Im confused some more posters please weigh in please.
