B
Beck
Guest
Yup, that tape will likely cause problems. The tape medium is one of the first things to look at when diagnosing machine issues. I would go into an explanation of what Ampex branded 456 and 406 tapes are ok, but when you buy them used none of the rules apply... since you can't be sure what kind of tape is actually on the reel, no matter what the reel and box says. If you've got AGFA 469 that will be as bad or worse than Ampex. Do all your diagnostics on new tape, and by new I mean unopened. Good tape can be 15 years old and still be "New." As already mentioned, look for unopened "New Old Stock" Quantegy 406 or 456, as well as 3M/Scotch 206, and 911 or 468 from BASF, EMTEC or RMGI. 468 from AGFA is the original and also one of my favs, but harder to find.
As for the pinch roller, its worth the cost of a new or reconditioned one. If you're using a piece of foam or anything else other than rubber designed for it you already have plenty of other problems you may not be aware of. The foam could also be shredding off in layers hard to see with the naked eye and contributing to the dropout problem. The proper function of the pinch-roller and capstan together in pulling the tape through the tape path is one of the most critical on the mechanical side of things. It can't be understated. And when you have microprocessor controlled tape handling, as you do on the MSR-16, it can be even more problematic. You got your MSR-16 for about 10% of what it was new, so expect to invest in common maintenance parts such as the pinch roller. Or I'll buy it from you for $700.00 and I'll happily buy a pinch roller for it!
It's well worth it!
