K
Kerfoot32
When I render a song or a track down to a wav, the wav file is a lot quieter then it sounded in the project. Why does this happen?
It shouldn't be quieter.
People telling you it's too low is not the same issue as having a different output level. When you compare the Wav of the final mix versus the project, how are you doing that?
Until you master your final mix, it's totally normal that it will be lower in volume to a finished, mastered CD or song.
It's quieter than what?It is quieter. They're telling me it's too low but it didn't sound low in reaper. I do compare wavs. Like I already said I listen in vlc and zune. It's not a monitor issue either because the knb doesnt change between reaper and vlc but vlc is quieter.
I'm not comparing the wav to the volume of a commercial song. I'm comparing it to the volume of the reaper project. I want to know why the rendered wav is quieter than the reaper project.
