J
jaynm26
Farview the book was published in 2006! dBFS has not changed and it never will First you refuted gain staging now your trying to say you support it I have not misunderstood you changed arguments.
Mixes just have to be peaking under 0dbfs. The only time you really have to worry about level is when you are recording (keep the levels averaging around -18dbfs while keeping the peaks below 0dbfs). Any other time, you just have to make sure it is below 0dbfs and you will be fine.
You are missing my point. the only time the average level is relevant is in the analog world. Once inside the box, the only thing that matters is not clipping.
you will find, with time....
that bringing tracks into your daw, that are peaking much higher than about -10db, will eventually create a bit of a 'harsh' sound in the collective..
again, it goes back to proper gain staging.
The harshness from running your levels too hot happens on the analog side, not the digital side.
But just one more thing about your advice that the mix should be averaging about -18dbfs rms (I agree with that) and peaking at -10dbfs. Most commercial CDs...
What year was this interview? In the early days of digital (up to the late 90's) most converters were calibrated to line level = -10dbfs or -12dbfs, depending on the converters. You had to deal with things much differently back then. In fact, back then, the big problem was not being able to run the preamps hot enough.
+3vu is -15dbfs rms, however the peaks will be much higher, so this is irrelevent.
Almost all daws us floating point math in the summing buss, which gives a virtual headroom of around 1500db over the digital noise floor.
Because of that, you can simply turn down the master buss to keep the mix from clipping the converters In that situation, the only time going over 0dbfs creates distortion is when it's fed out of the converters, because the converters have to resolve to 24 bits fixed point. ITB, there is no distortion at that high level.
you are using hardware emulation plugins that are designed to distort and do the same thing an analog piece of gear would if you pushed the levels to it. That isn't because it's distorting digitally, it's because that is a feature of the plugin that it emulates the way the analog counterpart would react.
Your points about gain staging and the recording chain are spot on and I agree with them, how ever I get the impression that you think the harshness of high levels comes from the digital side of things, when it is really the analog side of things getting wheezy at those levels.
Mike Senior Arthor of Mixing Secerets states, " However, when you have a digital signal that is clipping, it is being permanently and irreparably distorted and damaged. We're no longer making a perfect copy of the signal we're trying to reproduce, we're distorting it in a very unpleasing way. Even if you turn down the Master Fader the clipped distorted sound is still apart of the audio signal it self. It will go away on the master but the track that is clipping is sending a clipped distorted signal to the Master fader. Just imagine every track was at 0 then you would have all distortion and unwanted sound going to you Master fader. So as a general rule of thumb, you NEVER want to see clipping in a digital system. That includes not only your software, but also your soundcard. and converters. So, clipping is bad, we all understand that, right?"
Bobby your wayyyy off. We are not discussing save file or permanent we all know everything can be redone. we are saying once you print the mix with digital clipping its permeant yea save file/ session all that jazz its clipping thas the point. its about digital clipping and distortion in the digital domain thas the argument.
No hard feelings, there's nothing to debate. It's very well known how floating point math works, now you know too.No hard feelings Farview I hope...Lets move on to something else less debatable.
