D
Doctor Varney
Cave dwelling Luddite
Me again, with the audio spoken word...!
In trying to speed up my game here, I decided to experiment with a limiter algorithm and wonder if I'm wise to use it. Let me first explain the situation...
When I record my speech into the audio logger, despite my experience with voice work, there are always some inevitable peaks which cause a limitation to the normalisation algorithm, in that the waveform won't normalise anywhere past 0dB (which is the whole idea of normalisation, right?). So I do often find myself manually attentuating some of the naughty spikes. Then, when normalisation takes place, I get a louder recording overall.
Before anyone says "Stop looking and listen..." let me say that the visual waveform is my indicator of what's going on, before I hear it. I've learned to associate what I see with what I hear in a reasonably accurate manner. I DO listen more than I look at waveforms on the screen and the question surrounds what I should be aiming for in audible terms.
Now I've just discovered that I can apply a limiter algorithm to the waveform which saves a lot of manual work. It could actually mean the difference in turnaround for my business, if you add all the minutes I spend manually editing. Of course, I'm not aiming to remove all of the variance in the waveform to undynamic blandness but some form of conformity of the peaks is what I understand as the job of a limiter and this is what I want, only to a less aggressive degree.
So far I've got as far as applying the default setting and what I end up with is a very mechanical looking waveform. On first blush, it doesn't sound bad but it's hard to tell if this would suit the discerning ear or the equipment it's likely to be played back on. I remember someone in a previous discussion suggesting that the full dynamics of the voice are needed in the spoken word and to an extent, I would tend to agree. It's just that these excessive spikes are causing the rest of the recording to be rather quiet. I figured I've got some technology here, so I might as well learn how to use it to speed up the process.
What I'm attempting to ask is whether limiting vocals is a standard practice and begging for some tips on how to approach it. I've heard of 'hard' and 'soft' limiting and I presume 'hard' is what I've achieved here, with the even 'comb' effect; while 'soft' limiting is going result in more variance (dynamics) to the sound? I'm guessing here, so have I got that right?
Also I read somewhere that a limiter is simply a compressor which limits everything to +0dB gain. If so, then I presume I've chosen the right tool, as +0 is pretty much where I want to start at and then drop levels later in the mix, to give some overhead.
I don't feel 100% confident with my use of the limiter yet, but I think I'm getting it. I just want to learn more about it's proper uses in the industry (esp. with respect to vocals). If anyone could offer any rules of thumb; dos and don'ts; things to look out for, etc, I'd be most grateful. I've heard a few jokes about people who abuse the compressor and the limiter and so obviously I would prefer to get off on the right foot with this concept.
And yes, I am looking towards purchasing a better mic in future - but for now, I must stick with what I have and make the best use of it for the time being.
Thanks.
Thanks.
