P
paresh
Member
Hi - Maybe this should be posted under mixing?
I have never been clear on some issues around aux sends:
pre or post? post for reverb & pre for everything else??
sometimes I just have one track to send & don't need to blend 2 or more tracks (like a lead vocal) - so in that case should the send level be all the way up?
in the return bus do I get my volume level with the bus fader or the vst fx controls which often have an output level?
and for reverb for example, are you supposed to set it fully wet since they usually give you a wet/dry control?
Thanks for yr patience & wisdom!
