MissingDR.King
Im on a budget, everybody keep telling me a good mic preamp runs for 700 to 1200 hundred, i only have three hundred what do I do, I'm also working with a condenser microphone
OK, here's another little snippet while Jim stuffs his gob
A nice quiet and good sounding preamp is the M-Audio DMP3. 2 clean channels, lots of gain. Inexpensive, and I think it is going out of production so there could be some bargains around.
Anyway, here's my advice.
When you record, leave the channel slider in the DAW on the 0dB position. Use gain control on your preamp or interface as you watch the channel meter in the DAW. The channel meter will typically show a bouncing colour graph display, as well as showing the peak signal level in number format. You should use the gain control so that you get channel peak of -18dB to -12dB.
When you see channel peaks at 0dB or +something dB when tracking, you have reached digital clipping, which means you have lost audio information and the result is just ugly.
This approach might not show much of a wave graphic while you track, and it might sound soft when you monitor. This is expected and correct. Crank up the monitor if you can't hear, but don't crank the channel gain or use the channel slider when tracking.
This is the way to get clean recordings. You can fiddle with levels later when you mix, and you can raise the overall volume before you export.
Paul
