miroslav
Cosmic Cowboy
Yeah...recording twice is the way for a lot of stuff...but when I do that, I almost always use a different guitar, or amp, or settings on the amp to get that layered feel.
I find that if/when you want *exactly* the same guitar/amp/sound twice, with perfect timing, for panning purposes...playing it twice is almost impossible to get unless you are a robot.
So...if you are looking for the super-tight perfection, you can end up with more smear than perfection when playing twice.
And yes...there are times when you may want *exactly* the same thing twice for delay/panning purposes...where you want that much accuracy with the two tracks. It's not always needed, but sometimes it IS the sound that works, because you get that perfect delayed bounce from L-R of the two tracks.
Of course sometimes that little bit of smearing caused by a human playing twice can also be THE sound that you want and what works.
I just wouldn't always exclude or include one or the other approach as any SOP.
I don't have a totally negative view of the split/pan/delay approach, and I have used it enough times to know it can work, but it always depends on the song and what you want.
That said...specifically for a "bigger guitar sound"...I would go with the playing twice and chanhing of amp/guitar/settings.
The split/pan/delay I would use more for effect type purposes.
