*clears throath*,
First things first, you already know flats, flats are sharps going the other way, A, A#, B, C, C#, D, D#, E, F, F#, G, G# is also A, Bb, B, C, Db, D, Eb, E, F, Gb, G, Ab, so you know this now, this is called the chromatic scale, (ie, has all 12 notes in it)
So F# and Gb are the same thing,
Next, Major and Minor are tonalities, these are based off of an ancient system called Modes,
Modes were basically a scale of steps and half steps that made a particular sound like if you press all the white keys starting and ending at C you get a major scale, if you start at A you get a minor scale, these were originally the Ionian (major) and Aeolian (minor) modes based on all the white keys starting on Doh and Lah,
But the use of modes is not very commonly understood today so we say major or minor meaning happy or sad sounding overall,
a chord is made up of 4 notes (a triad is 3 before anyone jumps in there) and a major chord is root 3rd 5th and root', note the ' after root which means above, so for instance C E G C is the chord of c, but if you flatten the third you get the minor so R b3 5 R' of CEGC is C Eb G C which is a C minor chord,
NB: flattening the third will NOT find the relative minor chord, just find the minor version of THAT chord,
next on to key,
keys are basically a series of chords and notes on a scale that match together in a song for instance a song in C major, will have CDEFGABC and the major chords will be I IV and V as with all major keys,
I IV and V in C is C F G It'll also have it relative minor chord (vi) [note lowercase] and its secondary minor (ii) which in C are Am and Dm,
These chords sound great with this scale and key,
As I said this I, IV, V, vi, ii can be used with any key so in the key of G its G, C, D, Em, Am, and so forth, this is the basis of transposing aswell or at least a handy way of doing it,
so now we've covered keys notes tonality and sharps and flats, the last thing I wanna mention is cadences, as with guitar, a lot of chords sound well when put together but at the end of a musical phrase (think of 4 chords that make a line or a verse whatever) there needs to be a cadence, there are two types of cadence and two subtypes of each, a Perfect (finished) cadence and an Imperfect (unfinished) Cadence,
A Perfect cadence can be either Perfect (Authentic) or Plagal (Amen) a perfect is V - I and sounds good for endings of sections or songs outright and a Plagal sounds like the Famous church choir Aaaaaaaaa-mennnnnn, It is IV - I so try playing an G - C or an F - C and see if you can here it,
Imperfect cadences are used when you don't want the section to sound finished just yet like after the second line in the verse when theres 2 more left etc,
there are two types here aswell deceptive and Half these are V - Anything other than I (deceptive) and anything - V Half
this should help you get started, a lot of its off the top of my head and I'm trying to use American instead of british terms so sorry if I mixed them up but its a good starting point
anyway good luck on the keys
