TyphoidHippo
1Trillion K Platinum User
Your post seems to be saying "it's rare that you can get perfect results from a noise remover". I agree, but didn't feel like elaborating on something not asked about. You seem to be taking issue with the word "cancel". Call it reverse EQ then. Cool with me.
You're ultimately flipping the sign somewhere and summing sample values, which is an attempt at "cancellation" in my mind. I suppose I could have said "attempt to cancel".
I'm gonna start using "algebraically" to describe more algorithms. Definitely can't have one without. Oh - if you use an FFT at any point, and I can think of several possible uses here, there's trigonometry, too. You could say you trigonometrically remove the analyzed noise sample from the signal. That sounds hardcore - high five.
You're ultimately flipping the sign somewhere and summing sample values, which is an attempt at "cancellation" in my mind. I suppose I could have said "attempt to cancel".I'm gonna start using "algebraically" to describe more algorithms. Definitely can't have one without. Oh - if you use an FFT at any point, and I can think of several possible uses here, there's trigonometry, too. You could say you trigonometrically remove the analyzed noise sample from the signal. That sounds hardcore - high five.
. Don't read my post as snarky - just discussing what you said, and some goofiness at the end. Another smiley fail...I'm trying to get better with the smilies!
