Complete Novice! Info on building a basic studio?
  • Thread starter Thread starter rorusurus
R
rorusurus
I was recently given an alesis adat lx20 8 track. I play the guitar and would like to set up a very basic studio to do some multi-tracking.
What basic equipment do I need to start?
Mixer, amp, pre-amp??
Any help gratefully recieved.
Rory
Basic Equipment Requirements
I read through this article but it seems to refer to using a computer. I would prefer not to use a computer and would just like to know the equipment needed to do some multi-tracking at home?
Alesis lx20 + ?
Thanks in advance
Rory
Alesis lx20 + ?
Thanks in advance
Rory
Are you wanting to record strictly analog then?
I don't know the lx20 but it looks like it has separate record arms for all 8 line level inputs.
So, if you want to use several microphones at once, you either need an 8 channel preamp with line outputs per channel,
or a small mixer with at least 8 discreet mic preamps and corresponding line outputs.
If you just want to record a guitar (via cable), you'd need a DI box with line output, or a preamp with instrument level input and line output.
You'll also need a way of listening and again, the unit only has line level I/O so if you went with the mixer option you could route the lx20 back to the mixer and let it provide you with outputs for active speakers or an amp and speakers, a volume control and probably a headphone output too.
Looking at it, a 10 channel mixer is probably the best way to go about it.
Maybe someone else has ideas?
