Thanks for this info, Dale and Chuck! Fascinating! First time I've seen a mathematical analysis of my voice's low frequency. Growing up always being teased about how low it was, I hated my voice until I was offered a job in radio because of it. (If anybody had told me when I was a kid that I would one day make money with my voice, I would have assumed they were just making fun of me!) My daughter, who also does VO, has a low voice too:
Chuck, so sorry about the blind test. I might not understand what a blind test means. But by putting its corresponding settings in the name of each file I was hoping I was giving enough details about each. But I guess even knowing where the knobs were set, it still comes down to simply listening for which settings were the best. And 'best' is subjective, I know. But Chuck, I truly have no "ear" at all. The read I though sounded best was the 4th read (so the one where the compression threshold was at 2:45, the Exp Thresh at about 10:30, and comp ration at 2 o'clock.) Here's a photo of the front of my model of 528e, to reference how those clock settings translate:
www.debraleigh.com/Symetrix_Front.jpg
After reading your comment about the second one seeming to have a better "balance between dampening sibilance and losing high frequency content" I went back and forth between that 2nd one and the 4th a few times, and could then see what you mean. The 4th has pretty strong sibilance, doesn't it? And the 2nd one sounds better than I thought it did last night. Some of the tweaking I was trying last night was creating what I think of as a heavily gated sound, very artificial sounding, and I originally thought I heard that in the 2nd one. My 'ear' is such a joke.
And, yeah, I did think compression somehow helped diminish room noise, or hide it. While recording the first file ("NoCompression_NoEQ_DeEssFreq3Thresh9-15.wav") I could hear room ambiance, and when I did the hardlimiting while converting that file to an mp3, I thought I heard a big boost in that 'noise', but just now, listening to both the .wav and .mp3, it seems like I don't hear it. Maybe I just had my headphones too loud during editing? Sigh. I take a step or two forward, then several steps backwards it seems. Chuck, what do you think of that first file, where I didn't even have the compression on? If you were me, would you actually go with those settings? Sorry to have used up so much of your time already, and now to ask for even more.
Hahaha! "I don't believe people listen to audio books with sub-woofers". Thank goodness!
But my editing software DOES have a High Pass Filter. Its description says the HPF is used "to pass high frequencies and remove low frequencies. You must specify a cutoff point in order to determine a starting point at which the frequencies will be passed or rejected" On the HPF screen I don't see fields for both a "cutoff" and "starting" point. Do you? Here's what the HPF screen looks like. I'm not sure in which field I should insert 100?
http://www.debraleigh.com/HighPassFilter_SettingsScreen.jpg
Thanks again for all your help, and I promise to leave you guys alone after this. (I'll start recording tomorrow, so I'll be too busy to bug you!)
