Lt. Bob
Spread the Daf!
there's really never a reason to record a voice in stereo first off ...... you get nothing from doing that except an identical track. It's not stereo if you record a single source no matter how you pan it so even with the 57's you should still record a voice mono.I'm doing a stereo recording two times and panning them apart at the same volume. That said, I usually only do that when I don't feel like using the LDC for whatever reason...so should I probably just solely use the LDC, double track, don't pan, and then play one track at a lower volume?
And the only comment about panning a double tracked vox in this thread says that they DON'T like doubled vox if they're not panned.
