grimtraveller
If only for a moment.....
The click isn't new. It's been used for centuries. It's how multitudes have learned good timekeeping and as a result, to do the things Farview points out need to be done to successfully play a piece.When you play to a drummer, you are playing to something else's timing. Playing to a click isn't any different. If you can't anticipate the next beat, you really need more practice.
If you can't figure out how your part is supposed to sit against the metronome, you really don't know your part. You may know what notes to play in what order, but if you don't know when they belong, you are only doing half your job. And you clearly don't understand the part you are trying to play.
You know, there are plenty of classically trained players of instruments that know every thing there is to know about music and the relationship of every note and chord and whom, if you put a score in front of them will reproduce it faithfully and who may even have perfect pitch, yet who have not got the simplicity of Farview's statement down pat. So they will find it hard to remain in the kinds of esoteric times that have developed in popular music over the last 50 years. And they will sometimes suggest/play notes and/or chords that theoretically are within the vast scope of the piece, yet have the effect of being out of tune because they've approached the particular music theoretically rather than as it is.The main two jobs a musician has are being in tune and in time.
For sure, some will take to this easier than others. But take to it all that play music must.However, if your timing is not yet developed enough to be able to play with "click" - then you really should work to improve your timing.
All musicians should have a well developed internal clock that allows them to keep accurate time
I reckon most of that is a concentration and/or stubbornness problem. The hardest parts for me to play are those simple unadventurous parts that require the same part over and over. Because it is so repetitive it's easy to switch off. But concentration is one of the more vital qualities in a musician's armory.I don't buy it. I know tons of good players who can't record to a click. They all do fine with drummers but clicks are a problem. But playing to a normal click track is something a lot of player struggle with.
And here is the key to why concentration is so important. Many home recorders do so on their own. For me, saying 'I can't use a click' is like a driver saying 'I can't use power steering'.i am recording by myself. (If that wasnt already obvious)
Or wear slippers and use the cat. Apparently quite soothing.......*Image of Armistice yelling "Stop tapping your f*cking foot while you're playing, godammit!!!!" to band partner whose tapping is clearly being picked up by microphone*
Not such a great thing when recording acoustic guitars - you have to foot tap quite gently.....
"nawmean?"
