35chevy
Member
Hello everyone, this is my first post. Good to meet all of you.
I'm new to recording and I'll be hanging around trying to learn as mush as possible. I have pro tools 8 m-powered and a m-audio profire 2626. I have an exterior building behind my home that I will be attempting to record in but it needs help. It sounds like a train wreck. I'm posting a couple of pictures so hopefully you guys can give me some pointers where to start taming this space. It is a 12x25 with 3 windows, one entry door, and a insulated garage door. The walls and ceiling are OSB and the floor is painted concrete. I believe the ceiling height is in the 7.5 ft range. I have read about owens corning 703, bass traps, diffusers, and moving blankets, but i'm not sure how much I need or where to place everything. Please take a look at these pics and give me some ideas. I am currently trying to get rid of the stuff that is stored in there so the clutter will be gone soon hopefully. Thanks.
I found using Auralex (the only place I would ever use it-EVER!!) above the overhead mic's, helped to reduce side reflections and seemed a bit more accurate sounding. That being said, the fact that your control room is in the same room as your gear, you may need to make some sacrifices. #1 is getting the low end and first reflections under control for your monitoring of the recorded sounds. Getting correct mic placement will be a trial and error situation when recording in the same room. I have been there. It does not really take that long if you have the room treatment to be able to actually hear what is happening. A 'live' recording room, is treated in a different way than a control room. The fact that you have to use the same room for both, means that you are best off treating it as a control room. Then work on the rest of it if needed.
