I built one a couple of years ago for a client who lived in an apartment and wanted to play Sax in the room. It was 3'x4'x7' and was constructed with 2 sheets of 3/4" MDF glued together for mass. The unit was screwed together with drywall screws so that it could be taklen apart at a later date. The size would not fit through the doorway so it was assembled on site. The booth was raised up on casters so that it was portable in the room and it had only 4 small points of sound transmission to the floor. Carpet was below.
I made a vent system with a small quiet bath fan, isolated from the booth, and some insulated flex duct for the supply and return. (long pieces with several bends) A vent system is a must!!
The door was made from MDF with hindges and a latch. Some foam was used at ear level to reduce the early reflection.
I took apart a power strip and fed the wire through a small hole and sealed the hole for power inside the unit. I also added a small light in the booth. You will also need a mic cable and headphone jack wired inside the booth.
From inside the booth, it was very quiet. The outside sounds were blocked very well. Outside of the booth, the Alto Sax, being a loud instrument could be distinctly heard. About the volume of normal voices. Outside the apartment the Sax was barely audible.
I am sure that Mass Loaded Vinyl added between the sheets would have made it much quieter however we were working with a budget.
The overall sound inside the booth was "boxey" and recording vocals in a small confined space will color the sound.
I am ready to start building my own semi portable vocal booth because I live in an apartment and would like to build a booth that is maybe 7ft high 4ft wide or so...Small enough to put a mic and 1 person in to record dead quiet vocals. What materials are needed as I wanna just go in and purchase all materials first and take my time and put it together. Thanks in advance..
