C
Consul Records
Hi. I am a producer and I just moved into a new flat and i need to acoustically treat the new room I will live and produce\mix my music in. The room is 2.8x5m long and 2.8m tall and the walls are made out of cement. Currently My table is placed in front of the window facing the door with a pair of Yamaha hm80s reference monitors (bass reflex on back side). The sound is very sloppy with very lowered hearable bass response starting from at aprox. 180 hz after which there is a significant jump at about 130 hz and then coming down again.
I have attached a scheme of my room and of the objects in it. The sizes on the drawing should all be proportional to give you a better idea of what it looks like.
So what I need is are some tips about where would it be most suitable to place my table and bed (considering the closet is a corner-closet and rather be not moved) and what kind of isolation would I need to use and where to get the most accurate sound out of my monitors.
My budget is up to a 1000$
Thanks to everyone who helps.
