B
BrentDomann
Has a Dedicated Member.
Louder is better. Deal with it.
Can you define the way you're using "louder" for us?
that doesn't sound right. If you're staying at the top of the range and are always up to the last bit before peaking, then in a 20 bit system wouldn't that mean you're always using 18-18 bits? At least as far as accuracy and fidelity goes.I'm afraid it's a lot worse than that. Using the top 4-6 bits would mean the material has got 24 to 36dB of dynamic range since each bit is roughly equal to 6dB of DR. You will be hard pressed to find this in even the most dynamic material. Sadly, most modern pop music has anywhere from 3 to 6 dB of dynamic range, and less! This would mean this music is utilizing only the top bit. And yes, I said BIT. ONE.
Cheers![]()
I've been collecting issues of albums with the most dynamics for a year and a half now. Guess I have to get rid of my vinyl transfers and 80s cd rips and find the latest remasters, because someone came up with formulas to prove there's the same amount of dynamics regardless of the use of tools to reduce them.
Let me know when you are ready to get rid of them...I'll give you and address where you can ship them.![]()
You may only be varying the dynamics by 1 bits' worth but you're using all the bits but 1.
