S
		Sharkey
Okay hey everyone, I need some advice on my home recording setup.
I had a fully functional studio, but I moved to a college dorm and changed some things. My new setup has me a little puzzled on how to operate correctly.
I'll explain my previous setup:
Audio Technica AT2035 connected to M-Audio Fast Track Pro, USB connected to laptop. Laptop program - Mixcraft 5*
M-Audio Fast Track Pro output to Peavey PV 10 mixer, laptop output to PV 10 mixer. Separate channels, into the two RCA channels.*
Line out from mixer to a surround sound amp, amp to set of speakers.*
When I would play music or play back what was recorded, it worked perfectly fine. When recording vocals for rapping or singing, I would mute the amp so that sound still comes from the mixer, but I direct the sound to headphones only so the speakers aren't picked up on the condenser mic.
That way perfectly worked, but when moving I didn't want to take the amp or the big house speakers.
So I went out and purchased KRK RP5 G2 Rokit monitors.
The monitors are connected via a 1/4inch cable, obviously one coming from the left and one from the right output on the PV10 mixer.*
I'm impressed by the sound quality, but that's besides the fact.*
The PV 10 has a monitor send nob and I originally thought that would allow me to turn the nob to zero and it would have the same effect as muting the amp. I realized that nob is actually for a separate 1/4inch port, not the left and right output I'm using.
So how do I record without the mic picking up the sound of speakers? I can't just turn down the mixer because the vocalist must hear theirselves and hear the music via headphones, directed from the Fast Track Pro into the mixer.
Also, I know Mixcraft isn't the best program but it's easy to use and I've fully learnt the program. I want a more professional program to work with, what do you recommend I start using??*
Thanks in advance!*
Thanks in advance!*
