K
kennyxloggins
Thing is my knowledge of what it is and how to use it stops there. If anyone could enlighten me and let me know if the thing is worth using I would be more than obliged
Friend? Some friend...
You realise he may have set you on the path to financial ruin by opening up the Pandora's Box of home recording...
What you really need to make it work properly is some good quality preamps... and a mixer... and some microphones....
Everyone here is poor.... put the recorder down and walk away quietly.. shhhhh.....![]()
Any suggestions for a decent preamp and mixer?
Btw, you guys rule
This is really the key question, the wheel on which this whole line of enquiry and advice turns. You've been somewhat vague in saying exactly what your aim is and how far or serious you want to be ~ at least in intent.There are lots of people still using similar recorders. What is your aim in doing home recording?
Once I started taking it somewhat seriously, the results were pretty good. I see no reason why you shouldn't try it out and see what you think.
I'm assuming based on your post that you're entirely new to this, so the MT4x could be a good, simple way to try out mutitracking without investing too much. Long term, it probably isn't much of a solution though.
To track with that machine, all you need is a dynamic mic. The pre-amps will be quite usable.
Finding good quality blank cassettes is getting to be a bit of a pain though.
My first recorder was a fostex 4 tracker (1985). Loved that rig and used it till I wore it out. Heatmiser has pegged it, I think--good rig to cut your teeth on, but pretty limited for serious endeavors.
I'm currently in the process of remixing a ton of songs that I've recorded down the years on an 8 track cassette. Because I also record digitally, I get the current practical benefit of both. I used the cassette for 17 years before the switchover and for what it is, I think it's great, especially if you're right at the start of your recording life. It will teach you lots of things that will come in good stead as you go on. I'll never knock cassette portastudios although I think 4 tracks is too limiting. I thought that even as a beginner, hence the move to 8 track. Even that has become limiting.These things must be built like tanks 'cause it still works perfect. Even the transport runs at close to the same speed
I've used the 488 so much that initially, the workflow was so much easier than the Akai DPS12i. Even now, it's very easy to use and particularly with effects, once I worked it out it seems so simple. But as I've used the DPS12i for a couple of years now, it's become simple to me. I remember, every time I used the DPS 12i initially, I had the manual with me. A recording session was at least one quarter me reading and trying to work out how things went ! Now I never need to look at it.When I upgraded from a Tascam 488 cassette multitracker to a Yamaha AW1600 DAW I found that the 488 was far easier to use and understand what was happening. I was playing with it (the 1600) so infrequently that I had to relearn the damn thing every time I used it
