Doing the Delay effect on Rap Vocals???
  • Thread starter Thread starter Freddie Crookz
F
Freddie Crookz
How do you do it? It's very seldom you'll here where an artist has a slight verb behind his words but I've been told it's done with Delay.. how do you do it in Cool Edit Pro or Audition?
I don't know how it's being done in your DAW but in cubase i just set DELAY on the insert channel, and i play with the delay knobs while hearing the recording.
Some times i just have to set delay on certain spots in the verse, example on the ends of a line, sounds so messy with delay all the way on rapping!
google is your friend. seriously.
just search
cool edit pro delay. first result's a winner, and an instant answer.
Delay as a verb affect? About 200ms with one repeat will do the trick.
Match the delay time to the song tempo or some multiple of it. And as Nakken said, only on the last word of a line. That goes for most styles, not just rap.
How about 1 millisecond with 200 repeats? Does that work?
:eek:
yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep yep. :p
Well spotted ! Well spotted ! Well spotted ! Well spotted ! Well spotted ! Well spotted ! Well spotted ! Well spotted ! Well spotted ! Well spotted ! Well spotted ! Well spotted ! Well spotted ! Well spotted ! Well spotted ! Well spotted ! Well spotted ! Well spotted ! Well spotted ! Well spotted ! Well spotted ! Well spotted ! Well spotted ! Well spotted ! Well spotted ! Well spotted ! Well spotted ! Well spotted ! Well spotted ! Well spotted ! Well spotted ! Well spotted ! Well spotted ! Well spotted ! Well spotted ! Well spotted ! Well spotted ! Well spotted ! Well spotted ! Well spotted ! Well spotted ! Well spotted ! Well spotted ! Well spotted ! Well spotted ! Well spotted ! Well spotted ! Well spotted ! Well spotted ! Well spotted ! Well spotted ! Well spotted ! Well spotted ! Well spotted ! Well spotted ! Well spotted ! Well spotted ! Well spotted !
Or maybe that should just be 'spotted' spotted spotted spotted spotted spotted spotted spotted spotted spotted spotted spotted spotted spotted spotted spotted spotted spotted spotted spotted spotted spotted spotted spotted spotted spotted spotted spotted spotted spotted..............
Or even just ted ted ted ted ted ted ted ted ted ted ted ted ted ted ted ted ted ted ted ted ted ted.........:p
