Lt. Bob
Spread the Daf!
And I don't want to contradict you but that foam kept the drivers' frame from rattling (buzzing) against the cab which is being loose since if it were completely tight it couldn't rattle (buzz) ...... You possibly could have fixed it by simply tightening the beejesus out of it's screws, thus tightening it against the cab too much to allow it to rattle. But it couldn't rattle if there wasn't room for the frame edges to move so it was loose regardless of how tight you might have felt the screws were. Loose isn't just the screws being tight or not ...... it's anything that allows some part of the speaker frame to move.
But the better way is too use something like you did to both seperate the frame from the cab and sealing any leak that might occur due to lack of a gasket. Also, overtightening the screws could conceivably flex the frame enough to bend it though that's fairly unlikely.
In either case, it wasn't a bad voice coil plus doing what you did fixed the other possible problem that GCalo mentioned.
Not to be picky but too many people only read a smidgeon of a thread and don't get all the info.
While I know GCalo's only point was to help, he clearly only read the first post and didn't look thru the thread at all or he'd have seen that.
