CrowsofFritz
Flamingo!
How long do you all think it will be until interfaces will have this "Superspeed" connection?
usb2 works with 16 simultaneous channels
Firewire400 does well over 100
Firewire800 twice that
Usb3 was estimated to actually do slightly less than fw400.. maybe 80 or so.
So there is very little incentive for manufacturers to make new hardware
when existing hardware works very well already.
More probable that Thunderbolt (many times faster than firewire and capable of hosting expansion boxes with PCI cards and multiple drives) will eventually overtake firewire for heavy data flow.
usb is less efficient and has more overhead than firewire.
It also on achieves its theoetical speed in BURST mode (file copys) and
is not great for SUSTAINED data transfer.
Usb works with what they call a master/slave relationship to cpu&harddrives,
whereas firewire is a more efficient peer-to-peer relationship-- that means faster.
The 480mb/s figure is very misleading..... a well known and documented thing.
Thats why you dont see any usb interfaces over 16channels.
Usb3 has the same master/slave overhead as usb2, so it will (probably) not be as fast as fw400 for SUSTAINED data transfer.
USB 3.0 is here now
True but in the age of multi core CPU's and most computers with a min of 4G RAM that arguement really doesn't hold water today. I just got a core i7 laptop with 8GB Ram and record to an 8 in Zoom USB interface with pretty much no latency bumps or glitches.
I have no proof of this, but IMO the audio manufacturers are just plain lazy. There's several very good USB interfaces that have 8 channels for recording with 96khz or better. The drivers wheather ASIO or other are very low latency, at least barely detectable. Yet companies like preSonus who make some fabulous firewire interfaces, made a really lousy USB interface compared to some of the others on the market.
Sorry but the cpu speed and ram is irrelevant.
I'm describing the DATA PIPE that flows in and out of the computer.
You could have a 50GHZ processor with 100GB of ram and the constricted size of the data pipe is gonna limit the bandwidth speed of the data.
I'm not arguing that Firewire isnt disappearing.
A lot of that also has to do with manufacturers just not wanting to pay royalties.
Just note that very very few FW800 interfaces exist although fw800 has been out for some time.
Mainly because very few people need 200+ simultaneous channels and its overkill.
The specs for FW1600 and FW3200 are out but nobodys moving on them for the same reason.
If usb3 or Thunderbolt devices come out, fine. I'm not saying they wont.
But there's no real rush because in the REAL WORLD usb2 and firewire are working for most people.
The problem is that Firewire is a dying (if not dead) technology among most other hardware vendors other than the audio interface world. Barely any new laptop (even top end ones) have firewire ports in them. You can still get cards for desktops assuming you have a free PCI slot in your computer.
Thunderbolt IMO will not take off. USB 3.0 is here now, there's way more devices out for it, and it's a much cheaper solution. Thunderbolt will require a 50 dollar cable per device, and they all have to be daisy chained together.
Thunderbolt was pretty much dead from the beginning as an optical interface. I work for a company that designs optics for storage devices, and cables have always been very pricy. While it was good that Apple decided to go to a copper wire, it was dumb to make it a proprietary connector.
Intel originally wanted to use a USB type connector, how cool would that have been? All for not.
It's not proprietary. It's a mini-Displayport connector, which is a published industry standard for computer monitors....
It would have been a big mistake. By using a standard video connector, it is able to provide data service while simultaneously delivering audio and video. Compared to that, running it over a USB connection would be lame.
You are right USB2 and Firewire are working for most people, but the fact is that firewire is still the predominate interface for Audio interfaces and it's going away. I agree about FW800, but again you are not finding any new PC's on the market with FW, and even Mac only is putting it on the high end mac book pro's.
