			Sifunkle
Just come across something that strikes me as odd, but it might just be I'm overlooking something.
I'm EQing some tracks in Cubase LE (with its 4-band parametric EQ) and have observed this a few times. Taking the example of the kick drum I'm currently doing: If I put only cuts into the EQ profile (no boosts) and play it, the peak level it tells me for that channel is -7.8 dB. If I then bypass the EQ and play it, it tells me -8.5 dB. These aren't just one-offs either; I've repeated several times and it's pretty consistent, in terms of the peak levels it gives and their timing.
Surely that's not right... If I'm only making cuts, how can the sound intensity possibly increase?
My current hypotheses:
1. CPU problems causing mistakes - this seems unlikely as it's repeating the exact same pattern.
2. The frequencies I've removed were somehow moderating the level of other frequencies - am I ignorant of some physics concept here?
3. Cubase LE is stupid - suspect this is quite likely.
I'm really starting to hate EQing. I'm trying to use it to get rid of excess dB while preserving frequencies that are important to the instruments, and... well when something counter intuitive like this happens, I really lose confidence.
(And I suppose it doesn't help that I've only got my tinny laptop speakers, or bass-heavy headphones to monitor through. Out of interest, which would you use?)
Your thoughts? Or suggestions?
Appreciate it,
Si
Appreciate it,
Si
		 ). With all of my crushing mixological inadequacy, I'm taking whatever small victories I can claim...
). With all of my crushing mixological inadequacy, I'm taking whatever small victories I can claim... I guess after I get the tone right with EQ I can compress to get the level up, but I've already done a fair bit of compression and it might get a bit too much.
