I have been doing more research on the laptop I want to buy for my home studio.
- Ok well let me stop you right there. If you are really building a home studio then why would you want a laptop? Are you planning on taking your home studio to Starbucks? If you want a laptop buy a laptop - if you are building a home studio - buy a desktop computer that stays in the home studio. You will get better equipment at a better price when you don't have to cram it all in to a 4 lb. plastic case that fits in your book bag.
I originally was looking at a PC because I am accustomed to them. I was probably going to buy a decked out Asus or Toshiba. After looking more thoroughly, custom computers like Rain, ADK, and PCaudiolabs seem to be the way to go and a Macbook Pro is even better.
From my experience buy what you are familiar with. "even better" is pretty subjective. It doesn't take a super computer to record music well. Although an old piece of crap machine may well have problems, nothing on the shelf today should have any issues. At least not any big brand computers that I know of. I currently own about 16 computers - HP, Compaq, Dell, Gateway, Toshiba, Sony, Mac and probably a few more. If anything I would say do not get a Dell or Gateway. Get an off the shelf machine.
The issues I found that come up quite often are related to latency issues and driver issues between software and hardware items in your DAW system, which straight out of the box MACs seem to have less of.
WHY do MACs have better performance??
What causes more prevalent errors or unwanted performance issues in PCs??
Latency issues are almost always solved by driver updates. And you only hear about them because people do not post threads saying:
- I hooked up new DAW interface and recorded some music and there was no latency issue - please discuss...
If you just ask around about the set up you are wanting, then you should find someone who is using a similar setup and can verify that it works, or check with the manufacturer before you buy it. I happen to run Cubase LE 4 on Vista 64bit without a problem (using an Alesis Multimix 16 USB2 with 16 dedicated channels) no latency issues no problems at all - I do not like Vista, but I don't really care because I only use the machine to run Cubase - so Vista isn't really much of an issue -
As far as Macs having better performance, I think that is quite up for debate. Not that I care to debate it - I have owned about 8 Macintosh Computers - they all work great - I have owned countless PC's "most" of them worked great - all the major brand stuff worked pretty well - once a system is set up and you are recording and it works how do you measure performance? How fast you can apply a sound process to a wave sample? Figure out what you will be doing a lot of and then buy a machine based on that - the basic rule of thumb I use is
1) Get a machine with a stable operating system (not the first release)
2) Get as fast and as many processors/cores you can afford
3) Get a LOT of ram
- these three basic things will almost always assure you the best power/performance for the money - just like 90% of all computer problems can be fixed by rebooting (unless you run linux in which case you are probably on the wrong forum).
As far as the errors on PC's its like was already stated - there are 742,000 independent PC hardware manufacturers versus 1 Mac hardware manufacturer - its simple logistics.
Is it the MAC (OS) vs PC windows operating software that is the root of the problem??
I would say that is definitely the root of the problem. Defining "the problem" is the real problem. As to the root of that I can not speculate.
I believe Rain, ADK, and PCaudiolabs run on windows platforms, so are they subject to the same issues that PC's have or a they set-up to run more error free like MAC's??
The issues you speak of are about 3rd party applications and hardware so all machines are susceptible regardless of make or model. This includes Macs.
If you use a laptop to record, does it have to be totally for recording? For example, would it be a disaster to use it for photos, to load your CD collection on and use it as a stereo, use as a word processor, and other simple stuff etc??
Would you use the same computer you use to monitor a patients vital signs and run their oxygen for downloading bit-torrent movies? Ok I know this isn't life and death its just MUSIC. This really just boils down to how much time you will spend recording and mixing music. How much do you care about it? If its just something you want to do occasionally then it wouldn't make sense to dedicate a machine to it. If you are going to be upset when some virus deletes all the songs you recorded over the last 6 months, get a dedicated machine, get a backup HD, keep the machine isolated and the Antivirus up to date and don't use it for ****.
Best of luck and ROCK ON!
- Wes
