What's your post-tracking process?
  • Thread starter Thread starter brand0nized
B
brand0nized
I'm just starting out on home recording and I'd like to get other recordists views who have more experience than me so that I can learn from you guys.
What are the steps you take in editing and mixing your song after you track everything? What comes first, and what comes last? Also, can you tell me why certain steps come before others?
If possible, could you give me specific steps and as much detail as you could?
Any help is greatly welcomed. Thank you!
Heya. I just saw your pretracking thread, may as well toss in my $0.02 on this one too. :)
I have a 3 piece rock band so it's simple really. I don't edit I just start over if I screw something up, but our stuff isn't very hard to play (vocals on the other hand...). When I do vocals and am having problems I go 1 song segment at a time, like do a whole verse, stop, gather myself, do a whole chorus, stop, gather myself. I can't deal with doing every line separately, it takes forever, bores me to death , and sounds wierd.
Making a mix of a 3piece band for me is easy enough if the work is done at the tracking stage. I'm sure it would get more complicated with more stuff in there, but I just have the bare bones rock trio. I have 2 tracks of drums (just a stereo of the whole kit, so my mics are already EQd in the submix) 2 tracks of bassline (DI and amp mic) blended, and a stereo mix of guitar (one through an amp sim and one amp mic - a new trick I've been messing around with, blending more than one guitar sound just to experiment making it fuller toned.)
I start the sliders in the middle. listen through all of it. drop out EQs if a certain tone is too much. Keep vocals blended, because they naturally stand out from music because of the sound of words, they don't have to be at a high volume to cut through a mix, same with guitar "leads", they stand out without being turned up because they are naturally noticable.
I like to have my bass part big, but I EQ it all so it is tight sounding big by getting rid of quite a bit of mid and some low, instead of too boomy wompy sounding whatever you call it. The guitar pretty much just gets left alone, the tone is just how the amp/sim is set and it gets tracked that way, as do the drums because I EQ them as I track since its a submix not an individual drum.
I drop the low EQ out of my vocals so they can be turned up a bit without getting boomy too, but I try to do as little as possible, and nothing extreme.
EQ should not be obvious, it just gets rid of stuff that muddies the mix, or cuts through harshly, rather than adding stuff. All the tracks get sent to a tiny bit of soft toned stereo reverb at the end because it helps smooth it all together, then I compress it, not much, just enough to make sure it doesn't spike digital distortion and all that. I guess that's "mastering" but to me its a start-to-finish process, not 3 separate concepts. This is a process for a very small band. If I had to use a second guitarist I would think that pan separating them a bit left and right would be a good place to start so they are two distinct parts.
This is of course just my amateur newbie take on it, but I'm curious what you do as other trail-and-error techniques may occur to you too.
"Thank God THAT'S done. Now, let's have a beer."
I usually go through all the parts I recorded and comp the different takes down to one or two nigh-perfect takes. e.g. I'll have recorded 3 tracks of the bass part; I'll pick my favorite, and listen through. If I find any mistakes or glitches or whatever, I'll paste in the same passage from one of the other two takes.
I think Greg probably has the most experienced approach to this.
I agree, "Editing" is kinda priority first, then I go about getting the idea in my head of the song (not to say you shouldn't already have an idea before any mics get plugged in lol)
First, I throw my jacket over Greg so that he stays warm during his nap.
After that, the first step is "faders up". That is, throw the faders up on all your tracks and just listen to a rough mix of what you got. Use that lsiten to decide your next step, the just let your muse direct you from there.
The last thing I do is wake Greg up so he can go home before I turn the alarm system on.
If you want more detail than that, you need more than some forum posts. What you're asking for is instruction on how to perform an entire job description for a MINUMUM of one job title. There are entire books of a few hundred pages or more written on that subject, and those usually are each lacking in one place or another.
IOW, get off the Internet and into a library or bookstore, as that's the form factor you ned to answer your questions (and there aren't enough Kindle or Nook e-versions of these kind of books available quite yet.)
You can take a look at the on-line Studio Reference Book Catalog, available from this webpage for a fairy comprehensive catalog of titles available from Amazon.com.
G.
G.
I'm reading some books on home recording, but one's a little outdated (still talking about SIAB's and tape recorders). I just wanted to get more insight on what you guys are actually doing in the present. Thanks for all the information so far!
I don't think it makes that much difference what you are using to record with, some of the tools may be different but the basic idea behind it all remains the same.
And taking a nap is taking a nap
