S
stevieb
Just another guy, really.
Played a fretless, briefly, while in New Orleans last weekend, and I was reminded of why I love that instrument so much- the tone of the strings is just so different, from first pluck to end of sustain. So, I am inspired to revive my fretless conversion project.
First decision will be: The MIM Fender Jazz bass, or the Peavey Millinium? Seems like a Jazz bass HAS to be fretless, but if I screw it up, I have trashed (in part) a $400 instrument. The Peavey, costing me less than $100 (after selling the little amp I got with it, I think I have about $50 in the thing) would not make me cry if it goes south... Input on that choice appreciated, but that's not my primary reason for this thread.
It is this: I found this "how-to," and I can not bring myself to believe I can get good results from a process that's so easy: Take a gander:
How to build a fretless bass | Beats´n´Bytes
I mean, he yanks the frets, FILLS THE SPACES WITH GLUE, sands it smooth, and just oils the fretboard- and he's DONE??!? Other how-to's would have you cutting wood strips to replace the frets, glueing them into place, sanding to a fair-thee-well, and then coating the (now) fingerboard with a thick coating of polyurethane- and using only flatwound strings. And even then, they tell you you will wear down the poly- and be sure to watch for that and re-poly it, lest you wear away the wood.
So, is the easy way advised? Or is it a good way to ruin a perfectly good guitar?
