D
diskobox
Hello,
I have a rehearsal space used also for recording,
the dimensions are approx. as follows. Length (9 metres), width (6 metres), height (6 metres)
I record through an Allen and Heath Mixwizard 16:2 mk3 onto PC (through Delta 1010lt sound card) or 8-track reel to reel.
I have a bunch of sm57 and 58s, a D112, 2 x Oktava Mc012s, and a couple of Large diaphragm Condensors (Audio Technica 3060, AKG C2000B)
The surrounding walls of the room are completely covered in carpet, as is the floor. The ceiling is plaster.
When I record drums everything sounds a bit dead. If i move the overheads away from the kit, or set up a room mic, the sound is more roomy, but lacks top end and sounds dull. Im assuming this is down to the carpet absorbing most the higher frequencies.
My question is, If I buy a load of wood panels (plywood for example) and lay them on the floor and/or lean them against the walls, will this make the room sound more lively?
p.s. I rent the space out and i will not be able to do anything like rip the carpet off the walls/install a proper wooden floor. Also, I want to capture a real room sound on my recordings, I don't want to further deaden the room and add artificial reverb.
thanks for looking and any help greatly appreciated!
thanks, Ian
thanks, Ian
