W
Webz
Hi there and thanks for such a great forum.
I've been meaning to take the line out of my combo valve amp direct into the PC soundcard for HD recording for quite a while now. Apparently you're supposed to get a preamp signal according to the amp's manufacturer (Marshall)
I do get it as well as decent levels with my current cabling.
The only problem is simple. Noise!
I get a continuous sizzle or frying sound coming in even without my guitar plugged in.
Just wanted to ask if anyone knows a way around this or of any simple equipment that might fix it. I don't hear the sizzle on the amps speaker cone only through the PC soundcard.
The card isn't that bad its supposed to be a Soundstorm with ASIO drivers.
I've heard of using a DI box between the two but apparently DI boxes aren't all safe to use with valve amps.
Any clues much appreciated.
