M
Maddox
Hi, everybody. I have some questions about Spectrum Analyzers and Flat Response Monitors.
If you guys could shed a light here, please, I'd be very grateful.
I use a DAW, and almost all the tools i use are VST plugins. That's why I often refer to situations involving the DAW Master Buss in these questions.
About Spectrum Analyzers
1 - I read somewhere about a way to check the room; maybe you guys can help clarify this:
It was writen that, in order to find the best place in the room to record, we should we should use an omni-directional mic and a Spectrum Analyzer, and position it on different places of the room, without music, to look for a specific response at the Spectrum Analyzer (the Spectrum Analyzer meters should form a smile figure, or an inverted smile figure, I can't recall).
If we can't find this smile figure, we should compensate with eq (for instance, if there´s too much Low End at the Spectrum, we then know that the Bass response in the room should be attenuated).
2 - Is it a good idea to put a VST Spectrum analyzer at the Master Buss of a DAW, in order to check the frequency balance of the overall mix ?
I tried this with some commercial tracks from bands like Nirvana, Beatles, Green Day, Radiohead, etc., and they all seem to have some things in common:
the high end and low end of the Spectrum are significantly less present than the Mid Range, wich, by its turn, is more prominent at it's low end (the mid range's low end, that is).
3 - I might be getting things mixed up here, but (I think it was on the same article i cited above), there was something about using a mic and a Spectrum Analyzer the same way as above, but this time with music.
That apparentely some well-known tracks will provide a better source (the smile thing) to be analyzed by the Spectrum Analyzer. The article even suggested some tracks to use (the only one I remember is "One", from Mettalica.)
But anyway, I think that was about checking the acoustic for P.A., not for indoor recording.
About Flat Response Monitors
1 - Why is the Flat Response Monitor preferable than the "Non-Flat" Response ?
2 - Is there a way to turn a regular monitor speakers into something next to Flat-Response Monitors ? Maybe equalizing the Master Buss of a DAW, or adjusting the Bass and/or Trebble buttons on the Monitors ?
Thank you.
- Is this accurate ?
- Is it really an omni-directional pattern the one to be used ?
- And are the smile thing true ? Is it an inverted smile or a normal one ?
- If so, what kind of response should I look for in the Spectrum Analyzer ?
- What are you guys's takes and opinions on this, please ?
- How much of that is true ?
Thank you.
Do I get a gold star now?
