G
Greg_L
Banned
Man you guys are like a pack of monkeys fucking a football.
Don't clip your pre's, leave some headroom.
/thread.
/thread.
/thread.
Which ones the football !!!!
No feces flinging. It was just a joke. I guess it hit a little close to home, huh?That must make you the monkey. Which makes sense, they way you like flinging your feces all over this BBS.
Not at all. You fling your feces at everyone at virtually every chance you get. One cannot take personally the rants of a sociopath.No feces flinging. It was just a joke. I guess it hit a little close to home, huh?
G.
Greg...stop with the feces...its in my hair now...
@RR: M-Audio rarely produces much in the way of useful specs. You're right, often times the necessary spec is not published. But just as often it is. There's plenty of prosumer level gear that specs it out. And if it's not spec'd, it can rather easily be figured out by anyone who has access to either a VU meter, a multitester or a simple oscillator.
Perhaps you'd accept that, at the level of the DAW software, there is NO single, standard, pre-defined correlation? So, with no manufacturer spec, looking only at the DAW meters, there's no possible way of knowing what voltage level is being applied to the converter inputs.You're the one that brought up the concepts of the varying types of dB scales and then made the claim that there is no correlation between the analog voltage and the digital FS scale. I was just correcting that false notion by reminding you that there is a correlation. and that it is determined by the converter calibration. Whether or not a company decides to publish that information is irrelevant to the reality.
G.
