S
Syed Junaid
I want to record the speech in acoustically live environment:
ICD-UX200 Recorder Microphone jack input for plug in power has
minimum input:
level 0.9 mV, 3 kilohms or lower impedance microphone.
ICD-PX820 Recorder Microphone jack input for plug in power has
minimum input:
level 0.5 mV, 3 kilohms or lower impedance microphone.
AT897“The signal appears across Pins 2 and 3; Pin 1 is ground (shield). Output phase is “Pin 2 hot”— positive acoustic pressure produces positive voltage at Pin 2. To avoid phase cancellation and poor sound, all mic cables must be wired consistently: Pin 1-to-Pin 1, etc.
Nominal open circuit output voltage shall be 10.0 mV (phantom) or 8.9 mV (battery) at 1 V, 1 Pascal. Output shall be low impedance balanced (200 ohms – phantom, or 300 ohms – battery).”
Spec. Sheets:
http://www.docs.sony.com/release/ICDPX820.pdf
http://www.docs.sony.com/release/ICDUX200.pdf
http://www.audio-technica.com/cms/resource_library/literature/3b4fdc7559bc013c/at897_submit.pdf
1) Can we use a Condenser microphone (Audio Technica AT897) in small consumer grade low end DVR e.g. Sony ICD-UX200 or ICD-PX820 after patching cable from XLR jack to stereo mini jack without compromising on audio quality? (e.g. low speech intelligibility, hiss sound etc.)Or is there something missing in this chain e.g. preamp or impedance matching transformer etc...
2) If hiss is inevitable in my chain then is there any good software which can delete this unwanted hiss and ambient noise?
3) I will patch it like this:
minimum input:
minimum input:
Spec. Sheets:
