lo.fi.love
Functionally obsessed.
Hey folks,
I thought I'd start a thread with tips on using dbx noise reduction. Please join me and add your own!
So, I noticed something interesting about dbx noise reduction causing compression errors. Remember that dbx NR compresses the incoming signal, and it is prone to causing nasty compression errors if not used carefully.
For example, I'm working on a piece which uses a series of 1/6th second-long tones, coming out of a keyed gate, peaking at -3dBu. When these "beeps" are sent into the dbx unit and onto the tape, monitoring on the playback head shows that I'm causing the compressor in the dbx unit to clamp down really hard on the signal, and it makes an unpleasant "pop" or "thump". Turning dbx off on that channel and relying on tape compression instead produces a very pleasant, smooth, sorta 'soft knee' compressed sound.
On tracks with intermittent surges in volume, regardless of peak level, dbx nr will add nasty compression artifacts. Turn NR off and just EQ the playback signal to taste instead of relying on noise reduction to remove tape hiss.
Anybody else?
Anybody else?
