flatfinger
Use every dam bit!
There are a few methods that involve calibrating your monitors using an SPL meter and pink noise ( B. Katz site ...digido.com or something please google) has details . The idea is to make it utterly repeatable so you "find a groove " so to speak. If you find yourself stacking compressors on top of compressor and pushing all the faders up you should try stopping that and turning up the monitor gain !!!!
I tend to side with the check it in as many environments and levels as you can team . Of course you know a mix is never really finished , you just run out of time or get fed up !!!!!!! This is made worse by digital and instant recall. I used to save so many iterations that I'd go batty trying to organize them !!!
It is advisible to check that the most important item ( the vocal if it's a pop tune ) is the absolute last thing to go away as you turn it down into infinity .
(unless the vocalist sucks ; . then bury them in effects !!!!
