Luckily, I made a FAQ before we started.
				In Tune said:
			Your opening sentence is not really correct. We are still recording audio. That audio is being stored in as digital data. There is a big difference.
Yes, it's audio.  I'm aware of the difference and aware that patching a cable from one audio output to another audio input, is just audio.
The reason I said that was because it's still a computer that's receiving and writing the signal to wave. I'm assuming that one computer is as good as another, if they're both capable of dealing with 32bit float, even though one is a cranky old laptop, while the other is a big stable Athlon desktop.  That's kind of more what I meant, if you'll excuse my innacuracy.
If I could magic up two identical systems, with identical sound cards, then part of the question would be eliminated, leaving only audio degradation in the cables to address.  The question would then be more whether it's going to be very noticable.
				tmix said:
			Is there any reason you just can't offload the files from one computer onto a disk or usb drive and import it direct to the laptop?
Yes there is.  The mixer in between gives the biggest clue.  I want to utilize the controls on the mixer, in real time, whilst recording.  I don't have a recorder but I do have a laptop (which has recording software).  If I can get this right by salvaging an old laptop, then it might save me buying a dedicated hardware recorder.
Since I've learned how to route out of the mixer and back in to the same computer, buying
anything new at all will seem superflous, but for the fact the physical wiring seems less complicated to me than attempting it inside one computer.
				G-Jay said:
			You are suggesting putting the audio through an additional d/a then a/d conversion and in between that running it through a Behringer mixer. I would expect a large degradation in quality.
Granted with the d/a but there is nothing wrong with the Behringer mixer.  It has a better, smoother reverb on it than the internal VSTs can offer.
The El-Cheapo was bought to over ride the standard IO on the laptop's crummy inbuilt sound, so we could trigger music and sound effects, into the pro-desk we hired and the big performance speakers.  It's a big improvement on sound out but absolutely no use for dubbbing because of it's latency problems.  That said, I did get an improvement on that score, when I updated Audacity to the beta version.
I'm trying to remember what the problem was and recalling now, that I was using a very rubbish mic into the input of El-Cheapo...  Of course, the E=MU removes all the variables and just delivers on all fronts.
				Massive Master said:
			I'm with that. Don't get me wrong - I run digital out through analog almost constantly. But the chain should be 'worth' running through. That one, I'd avoid.
That said, you can always try it.
Well, yes.  I'm surprised no one's asked why bother asking, when all you have to do to get your answer is to experiment.  The laptop needs salvaging out of the loft and this stray thought of mine ended up as a lazy question to the more experienced.  Just thought I'd run it past you, to save any dissapointments and in the hope you might have some better suggestions.
				TimOBrien said:
			In the first place, WHY are you sending audio from one computer to another using an analog connection?
As said, the mixer is the clue.  If I were gonna process the sound digitally, then I wouldn't bother sending it out as audio - but I want the physical qualities of the mixer and the only way to get those is to feed audio in and re-record it.  I think it's a perfectly respectable method - it's just that the equipment, I'm attempting to do it with, may be suspect.
Basically, I just want to change the way I mix, using the best of both worlds.  By employing the better sound quality of the digital and combining it with the physical real-world feel of the analogue.  If we got rid of the computers, then we'd be down to using those little Boss/Tascam recorders that write straight to CD-R and they are digital anyway.  All they've done is replaced
tape - and I
really don't want to go
there.  Since I have computers and a lot of post-production takes place in the computer, I thought I might as well use the computers like I would use hardware players and recorders.
I'm sorry if this all sounds a bit stupid... I'm learning and experimenting.
Dr. V
