C
chamelious
www.thesunexplodes.com
Does anyone know of one they'd trust?
I'm looking to get 4 or 5 tracks done, for one song.
Thanks.
Thanks.
What does a re-amp box do? Can't you just run a channel line out to the amp?Cool! I'm actually thinking of doing the re-amping myself at a local studio, the engineer says it can be done without a re-amp box, is this so?
It's when you record a track, usually for guitar, often with a DI off the instrument so that there is no amplifier character to the sound, and then play back the recorded track through an amp or combination of amps and effects and rerecord it. It lets you choose the amp and/or effects later and change your mind if you want.Im new hear and noticed this. I've heard the term often before, but I was wondering if someone could explain to me what reamping is?
Thanks.
Dude, If I were you, i'd just ask someone here to do it.
I trust each and every person here and I guarantee that they would be glad to help a fellow HR member.
Post it in the MP3 clinic and describe the tone you're looking for and I'm sure someone will help![]()
Haha. Its still relevent, we're preparing to do our album now and i'm going to be reamping.
However i have no interest in sims, i can do that myself. I'm probably going to be reamping my bands equipment in the local studio. (Peavey 3120, peavey 6505, orange tiny terror, cabs with v30s)
A DI box doesn't boost the signal, it attenuates it. so if you use it in reverse, you will end up with a signal that is higher impedance and higher output. This will force you to turn down the DAW output even more, which really screws with your gain staging. This creates noise and other silliness.1. Guitar output is what is colloquially referred to as High-Z (high impedance) low current (milli-amps) whereas line level is kind of the opposite, i.e. Low-Z with high current. You can tell this because you when plugging a line-level output into a guitar amp you have to turn the signal way down. The DI-box will convert the high-Z guitar output to low-Z (not sure if it boosts the signal at the same time). When you go back the other way (re-amping) you need a re-amping (reverse DI-box) to convert the low-Z to high-Z and possibly cut the input volume.
Why would you back off the mids on the way in? You aren't recording the DI for listening, you are recording it so you can run it back out to an amp. It doesn't matter what it sounds like.2. Guitar pickups have the characteristic of being quite dominant in the mid-range of frequency. Thus when recording using a DI-box into a DAW you have to compensate by rolling off the mid-range. Well, I believe the opposite needs to happen when re-amping line-level out to guitar amp in. That is, re-boost the mids before sending it to the amp, or possibly roll back base and treble. I haven't really tried the latter but believe it would be better to give the amp what it is classically expecting.
You simply record the guitar through a high quality active DI box, making sure the levels don't get too hot. (with active pickups, you can use a passive DI box) Then use a proper re-amp box, like the Radial X-amp, to get the signal back to the amp.Do you folk know what the standard (best) practice is in professional recording studios? Do they go to the bother of applying a re-amping box (reverse DI-box). Does taking the trouble to do this produce a noticeably different result?
