B
bdam123
Member
I did my forth mix tonight and A/B-ed it against a known producer's beat that we've been writing for. I'm pretty positive that his were rough mixes but they were very well done. I'm aiming to match him cause I'm assuming he is running on industry standard. If his is 100% I'd say I'm at about 35-40%. I'm also using his beat as a reference inside the session so it helped a lot.
I want to describe by current session setup and would like you guys to pick it apart. Please scrutinize willingly. I'm running PT8 btw.
Basically I am loading the dry audio bounced from my Logic sessions with rough leveling intact. I organize my tracks by instruments ie drums, bass, synth. My drums are being fed into a Drum Sub Mix aux which is being listened to by a Drum Master (to monitor clipping). The same is done for anything I can group. Everything is then being fed into a Sub Mix aux that also is being listened to by a Master. And finally Master Fader going to my outputs. I have auxes for all my effects ie reverb, delay, chorus, etc. which are also being fed into the Sub Mix aux.
I copied this basic setup from a couple different sessions from people posting videos online. I just took bits and pieces of everyone i checked out and kinda made my own. What do you guys think. Is there anything that I'm doing that you think is unnecessary?
Thanks.
Thanks.
