SouthSIDE Glen
independentrecording.net
Wow, this sh*t is even more annoying to watch from the sidelines than it is to be stuck in the middle of.
G.
G.
Well...if you don't have the space for monitors...then what kind of space do you have for tracking?![]()
And if you don't have the $$$...then how do you afford the other things you need? (I'm not talking about guys that have $400 and try to buy a "studio" made up of the cheapest stuff.) Even the most bare necessities for *good* studio are going to cost much more than that...so then why get all cheap/tight when it comes time for monitors?![]()
I'm sorry...but this idea by some that you CAN get a "studio" for a few hundred just by skipping over certain key gear...or just buying a lot of very cheap gear, well, is rather foolish, IMHO.
It's like buying only a small salad when you know you need a full meal...w/dessert. It doesn't work...you just end up being hungry and asking for more anyway.![]()
There's no requirement that it necessarily needs to sound "good" or whatever, just that it needs to function properly.
...but getting back to the OP's main question....
...the industry standard for a mixing playback system are monitors, not headphones. All the other side arguments are simply excuses to not having or being able to use them.
If you're talking strictly monitors, most home stuff is probably under $500 for the pair.The one thing I think the OP isn't considering, is that "industry standard" stuff is really up in the $1000's (i.e., plural or many) range, whereas most home stuff is generally under $2k.
... whereas most home stuff is generally under $2k.
The "industry standard" is indeed to use *high quality* monitors in a *high quality* room. That does NOT translate into meaning that monitors are always better than headphones regardless of any other variables. The real question/answer is just not that simplistic.
If one is using something along the lines of Logitec gaming speakers to mAudio BX5s in the corner of your typical basement or attic space, there is absolutely no advantage or ease of use issue to that kind of setup over the use of a halfway-decent pair of headphones. You're just trading one set of difficulties of another of roughly equal difficulty.
I don't know about that....
That said, I know what you are saying about many home setups not coming close to "industry standards"...it's just that to me, there are some basic pieces of gear one needs even for a decent hobby setup if the goal is to get the best possible results, and think that even the guys who only have a few hundred to drop on a home rig still want great quality.
I don't think many are going in thinking ahead it will only sound so-so….
It's kinda funny in an odd way...but I see a lot of perspectives on forums about what is good gear or what is a good technique or what is a good end-product...
...all being dictated by the poster’s wallet.
IOW...if all they have is a few hundred to spend on a rig, they will debate the validity and value of that rig quite vigorously/passionately and sometimes even argue that “buying up” is just about hype.![]()
One thing that I don't agree with is that you need anything that's particularly high-end to get results that will fool the average (and oftentimes, no so average) listener into thinking you used gear that's particularly high-end.
Which do you guys usually use to mix down? I usually go for speakers, but I get quite annoyed when it all sounds very cluttered on the headphones. Is there an industry standard for that per say?
the guys that spend a few hundred on what they call a "studio"...which is really a computer with a cheap A/D box/card w/built-in preamp, and a couple of $100 mics...
That certainly is not going to go toe-to-toe with an all-high-end audio chain.
( and my mics were cheaper)
... a computer with a cheap A/D box/card w/built-in preamp, and a couple of $100 mics...
I have one “expensive” mic ($1500-$2000 range)…and it certainly does give better sound quality for most vocals than several of my next line of mics ($500-$800 range)…and certainly WAY better than my “bottom” line ($100-$300 range).
I think that applies to a lot of audio gear…you just have to find your acceptable price-to-quality range.
i was reading an article/comment in Recording Magazine suggesting that all music internet message boards should be banned as basically they are just full of other peoples opinions and stop the person from actually going out and trying things...which is the only way they will truly find out if a piece of equipment is the right one for them..
just because something sounds different does not mean it is better. maybe it is, but maybe it is just different.
But so are the magazines...just check out all those reviews.
Naaaa...it's not the BBS that stop people from trying/buying...
...it's their budgets.
But I agree that there are a lot of opinions on forums based mainly on other people's opinions...and not the poster's individual hands-on experiences.
I think everyone passes on anecdotes to a degree...nothing wrong with that...but when you get into a debate with someone about finer points of some technique or process, and they're like 18, with 3 months of "experience" under their belt and the rest is just opinion derived from Internet sources...![]()
Since when is the audience the producer? Producing music on a technical level solely to make Joe mePod happy is setting the bar awfully low. Might as well just write commercial jingles on the back of an envelope and be done with it.depends on your audience. most people think mp3 is hi fi these days. you dont need more than a decent home set up to make them happy.
I use headphones for tracking and editing. I never use them when making any decisions about sound quality or balance. Speakers only for that. Personally, I don't know anyone who does good quality mix work that does it with headphones.Which do you guys usually use to mix down? I usually go for speakers,
IME a more common problem is that everything sounds rich and full through cans, then not when through speakers.but I get quite annoyed when it all sounds very cluttered on the headphones.
G.
I've done the hotel room thing.OK...those are valid justifications for NOT being able to play music loud or do any permanent remodeling, though I think near-field monitoring at 75-85 dB SPL is certainly not very loud and about equal to a typical stereo.
That still doesn't change what most people do & use as an "industry standard" (as much as there are some standards).
If I was forced to live in a hotel room for a month and still wanted to lay down some tracks, I might use a laptop and just bring a couple of mics and headphones...and make do.
Of course, under more ideal conditions, the gear and application would change more toward that “industry standard”…or as close as possible.
I never meant to suggest that headphones are totally unusable...quite the contrary.
AFA room treatment...I'm more of the "make do" mentality rather than frettin-n-fussin about room treatment before laying down a single note to hear how it sounds.![]()
