H
Halon451
Hello all... new to the forum, brand new to the world of recording so I have lots to learn yet. Hoping I could get some advice on an issue that has been bugging my efforts thus far.
To give some background, I have a strong engineering background, and have worked in industrial electrical and electronic applications for a number of years, so technical jargon doesn't frighten me, if someone has any in-depth insight into my issue, please feel free.
My humble equipment list is in my sig, I'm also running the Cubase on a laptop with just over 2G of RAM, a 1.8 GHz processor, Windows XP Professional (SP3), and my audio files are being recorded to an external 7200 RPM 750 GB hard drive.
The Firestudio Project of course has 8 inputs. Mics in use are Digital Reference DRM-7's on the drums, an SM-57 on Guitar 2, and another Digital Reference dynamic mic on Guitar 1. My band has been recording live utilizing all eight inputs in the following order:
Input 1: Kick drum
Input 2: Snare
Input 3: Rack tom
Input 4: Lower Toms (Shared mic between the two)
Input 5: Mixing board** (a mix of my two condenser overhead mics) via line input.
Input 6: Guitar 1
Input 7: Guitar 2
Input 8: Bass via direct input from bass amp pre-amp output.
As of yet we do not have a vocalist, but have figured on tracking him/her separately once we get one.
My issue is in Input #5. I want to be able to maximize the mic placement on my drums (I am the band's drummer incidentally), and capture the ambience/cymbal/hi-hat sounds, but am limited by the number of available inputs on the Firestudio - hence the use of the mixing board, which has its own +48V Phantom power supply to those mics.
Problem is, the sound comes through a bit fuzzy, even though no clipping indications anywhere in the signal path. I am wondering how best to eliminate this issue, or perhaps gain insight into a different direction I should be taking to get what I need?
My thought so far is possible issue with cascading/multiple gain stages by using the mixing board as a "mic combiner" essentially? Could introduce distortion that may not register on the meters as clipping? If so, how best to avoid this?
I have to say, as a noob - the mic placement and instrument arrangement thus far has provided adequate isolation to minimize bleed, and I've been using a shelving EQ approach on Input 5 to eliminate the unwanted/unnecessary bleed through sounds from the condensers - yet they are still fuzzy in the upper frequency ranges as well.
I would appreciate any help, thoughts, insights, or amusing anecdotes on this!! Thanks in advance.
Input 1: Kick drum
Input 2: Snare
Input 3: Rack tom
Input 6: Guitar 1
Input 7: Guitar 2
