thebigcheese
"Hi, I'm in Delaware."
Being unemployed has afforded me entirely too much free time, none of which I seem to want to spend doing anything particularly productive, so instead I thought I would try a little experiment. Whenever you try to compare what guitars sound like, you are always running them through an amp or whatever, listening to the guitar at its best. But what does the guitar really sound like? So I thought I'd plug it straight into my interface and see what the guitar's unaltered signal sounds like. If some more of you will do the same, maybe we can put together a little database of what different guitars actually sound like so people will have a better idea what the differences are. I have a hunch that a lot of guitars, mine included, are not going to sound that phenomenal, but as long as we're all playing fair and keeping the signal untouched, we should be able to compare to sound clips and get a general idea for how one guitar sounds compared to another. So here's some clips I did to start us off. They are done with an original Gibson "The Paul" (1979, I think) plugged straight into a MOTU Traveler. It's going through one of the four preamps, so it's not totally uncolored, but I think the preamps are fairly transparent. Anyway...
Bridge sample
Both pickups sample
Neck sample
Please contribute your own samples so we can compare! The only rules are that you have to use the most transparent preamp you have as we want the signal to be as raw as possible and you're not allowed to use any FX or alter the sound in any way in your DAW. Try to mix it up with single notes and chords and play the same thing for each of your clips (doesn't have to be what I played, just the same amongst your clips).
Bridge sample
Both pickups sample
Neck sample
